Discuss Running software on Ubuntu Linux in the Electrical Tools and Products area at ElectriciansForums.net
ringer
All my computers are running Ubuntu Linux operating system. I am assuming that any kit I buy that comes with software and interacts with the kit via downloads (such as MFTs) will only work on windows machines. Is this correct? Does anyone else on here use a linux OS?
I have so far managed to avoid installing wine - am trying to get away entirely from windows related software. And recent distributions of Linux, in particular Ubuntu, pretty much install and work ok with a default installation. Not like the bad old days of working out the configuration for yourself and constantly failing to get a working system.
But there is always the possibility that the software I would purchase (at a not inconsiderable sum) might not work. I do realise that these software packages will probably not do much more than take some raw ascii based data and format it nicely on a report, so do not expect major incompatabilities. I was just hoping that someone on here would be able to confirm that they had a similar setup and it all worked ok for them.
update:
Just received a reply from Brian Harper at EasyPAT - their software will only run in windows. And I thought they might be the most likely ones to have a linux solution. Looks like I may have to roll my own using Open Office Base.
Reply to Running software on Ubuntu Linux in the Electrical Tools and Products area at ElectriciansForums.net
I have recently got a Megger MFT1730 and wanted to give the Bluetooth download feature a try. The PowerSuite trial software that came with the...
4K
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
Background is we are selling our house and moving out of state. I've been fixing big and little things and painting for several months now, as...
I am having a debate about the requirements of earthing in an HMO - The incoming supply is 3ph 200amp and Gas and Water are bonded 50mm as needed...
