O
owenskinner
Hi All.
Am about to enter into the world of S Plan heating systems and need some general knowledge as I have none when it comes to plumbing.
The system comprises of the following:
It is a Danfoss S Plan With 2 * 2 Port Zone Valves With Programmable Heating & Hot Water Thermostats
1 Worcester Combi Boiler
1 Cylinder
1 Motorised Zone Valve
1 2 Port Valve For Hot Water
1 2 Port Valve For Heating
2 Channel Full Programmer
Ground Floor Room Wired Thermostat
2 Dual Cylinder Thermostat
I have the S Plan Schematic From The Cylinder and another from Danfoss Both Attached.
Which S Plan takes precedence? Danfoss, Cylinder or Worcester (There isn't one provided in the Worcester manual)? Is there an obvious reason why one takes precedence?
I am not sure where the two cylinder stats are supposed to be wired to as there is nothing I can see in either S Plan for the cylinder stats (Is this the 'Dual Aqua Stat'.
How do I know if the combo boiler needs the switched live or not? Is it standard that it always does in 'S/ Y/ W Plans'?
Will the boiler pump in this instance be within the Worcester Combi Boiler?
Any general information in addition to these questions also great fully received i.e. how the system works once wired and plumbed.. stat calls boiler, valves open to divert to zones etc etc.
As you can tell I am really green in this area but need to learn fast!
1 Cylinder
