P
pablo4321
Hi to do safe isolation on my am2, this monday coming would this be correct procedure, this is a individual circuit, supplying a motor via a rotary switch.Could anyone advise me if this is correct,thanks in advance
identify circuit.
lock off put key in pocket and display warning sign.
check voltage tester for damage
check on proving unit
turn rotary switch to on position
go to motor check for voltage between all phases earths neutrals etc
then check again on proving unit
identify circuit.
