Discuss Safe Zone in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is it safe to sink cable in a wall directly above a consumer unit? I know i can use the corners or a room up to 150mm and i know you can sink above, below left and right of switches and socket, as log as its RCD protected. (less than 50mm). I cant fint any thinkg in the 17th edition regs about this.
as long as the circuit you are wiring is rcd protected, or mechanically protected etc i would say yes, im presuming you mean the cable is coming directly out of the db so it would need to go above, below, or either side, there is nowhere else they could go! just make sure your not chasing into where there are already cables!
Good point there Paul.
So what happens when a cu is installed in a new position and the job finished, and then the chippy or homeowner decides to put a cupboard around it?
when u left it ir was in a safe zone so i can sleep at night. however for this reason i always use metal capping when above a CU just in case
Reply to Safe Zone in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've been told I need to upgrade the main earth bonding to 16mm. The consumer unit is on the wall adjacent to the externally mounted incoming...
4K
Hi there, We're currently having a new kitchen fitted and in the process we've had some new electrical work done. The electricains are comeing...
I'm renovating a property and vaulting a kitchen ceiling to gain more head height. The floor will be a slab which is yet to be laid. Would it be...
So, I'm having grid switches in my new kitchen for things like cooker hood, dishwasher, fridge freezer, integrated microwave etc...and know how to...
