Discuss Safety question with stripping in the USA area at ElectriciansForums.net
Never cut the wire unless it’s burnt. By code you should have 6 inches of wire hanging out of all boxes
intresting. here 6" of wires hanging out, we'd never get them into the boxes. some light switch boxes are only 5/8" deep. (most of us try and use 1" boxes for switches, or deeper for dimmers /smart switches).
In the UK most electrical work is in older properties where solid walls are the norm and metal box's have to be recessed into the brick or block, hence the 1" deep, or at most 1.3", on more modern construction where we have started to follow the US trend for timber studding larger box's can be used, but are not readily available.
50mm wouldn't be viable in a lot of jobs here when recessed into brick or block. Although sometimes it would make life easier
In my opinion I don’t think I could do what y’all have to go through to add outlets etc. or anything else. I applaud everyone on this forum
Reply to Safety question with stripping in the USA area at ElectriciansForums.net
I'm putting up a pegboard in my garage. There is one outlet behind where it will be. I bought a 12 outlet strip to mount on the wall. There will...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi first time on this forum and looking for some advice. I have a second home with incoming network connection as shown below. I don't like...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
