Hello, I have a safety question! My friend found a cable and argued that it was okay to touch it (and did touch it) because there's no probable way a coated fiber optic cable that had no voltage warning and was located next to a power line could cause you harm. Due to the fact it is coated and most likely properly insulated because it'd be a big mistake for an electrician to make. Do you think that what he did could have lead to harm in any way? He is not an electrician and thinks that he can make this call. He understands that as a rule of thumb you should not touch cables that are near a power line, but he claims he properly assessed the situation, and concluded that there was minimal risk involved. Is there any way I can convince him that what he did was stupid? Or am I in the wrong here?
This is the wire in question: View: https://Upload the image directly to the thread.com/a/PyCsURe
*note the warning doesn't say anything about high voltage, only about digging.
