Discuss Same Circuit for Hob and Double Oven in the UK Electrical Forum area at ElectriciansForums.net
nick741
Hi,
We’re having a new kitchen fitted, with a separate hob and double oven. The Hob is 6.4kW and the oven is 4.2kW totalling 10.6kW.
Would the below set up be ok for this?
  1. Consumer Unit with 50A MCB,
  2. 10mm T+E to 45A Cooker Switch (approx 13 metres),
  3. 10mm T+E to Dual Appliance Outlet (Scolmore 45A EASYFIT DUAL APPLIANCE OUTLET PLATE - https://www.superlecdirect.com/p-prw217-scolmore-45a-easyfit-dual-appliance-outlet-plate/),
  4. 4mm T+E to cooker and hob.
Is this set up ok considering it’s a 50A MCB with 45A switch and appliance outlet?
Also, is the 4mm T+E ok as it’s protected by a 50A MCB? I was under the impression that any change down in cable size should be protected?
Any advice would be appreciated
the dual appliance outlet plate is good practice.
Reply to Same Circuit for Hob and Double Oven in the UK Electrical Forum area at ElectriciansForums.net
Evening all, I'm upgrading my kitchen electrics replacing the current gas hob for an induction hob. The oven was previously plugged into the...
Hi all Some advice on this would be great. Due to wire a kitchen from scratch and in a pickle over the designing of the oven and hob circuits due...
Howdy experts, I normally run 6mm T+E for cooker circuits, housing authority spec. I'm changing my gas inbuilt double oven and hob for...
Hi Guys, I am just changing my plug top oven over & gas hob and noticed the following: 32AMP Breaker > 6MM Cable > Cooker Switch 45a > 4mm cable...
Hi folks, DIYer here, hoping for some advice before most likely calling in a spark. I'm looking to wire in new cooker and hob (separate units)...
