Discuss Scantronic Battery Fault in the Electrical Forum area at ElectriciansForums.net
DanBrown
Hi guys,,
i have a job to find a ''battery fault'' on an old scantronic alarm system, and with no alarm knowledge what-so-ever, i could do with any information you guys have..
With it having the ''battery fault'' on the display, makes it easier - as it obviously says fit a new battery to me.., but info and any tips would be greatly appreciated..
Thanks..
Hey Dan.
I think you've answered your querey already, battery fault = change battery, job done.
You might want to check all battery connections both at battery and PCB to make sure that the problem isn't a bad connection and also measure voltage at terminals on PCB to make sure the panel isn't frying the battery thrugh a faulty rectifier.
Cheers.
What is the correct procedure to fitting a new battery? obviously i dont want to kill the 230v mains supply, as i'll loose all programming as ther's no backup battery...
Also, i take it there will be a tamper on the control panel, so what do i expect?, all sirens? what.. What about access codes to shut it up, or put it into engineers mode?.
Thanks...
Hey mate.
My knowledge on this particular make is limited.
Access codes are unique to every panel theres no way of telling what they are.
The customer should know the code for arming/disarming the alarm, once it is disarmed you should be able to take the cover off with setting the siren off, although the older scantronics didn't work like that, they set the siren off even when disarmed when you removed the cover.
Even if this does happen punching in the code again should stop it.
Once your in you should be able to swap batterries no problem, after you've taken the old one out test the battery terminals before putting the new one in to make sure that isn't the cause of the battery fault.
After fitting the new one you may need to reset the system before it acknowledges the new battery, with the code punched in you should have access to all the user/engineer menu's to enable you to do this.
Hope this helps.
Thanks Guys.. Thats just what i wanted, and thats what makes this site popular..
Great advice for those in-experienced people..
im sure i had this problem a few years ago those codes sound right but depends if the engineer codes were changed at install. i think theres something to do with shorting out jumper pins to reset to factory settings if neccessary. you can register online to download manuals but icant remember where , sorry.
Hi have same issue as op . Where is the battery located in the control panel .or is there a separate box outside I need to open to ham access to battery
battery sits in the bottom of the control panel. you can't miss it.
Scantronic Battery Fault 1603784509359 - EletriciansForums.net
regs require the label showing the date of installation to be visible and facing you when you look at the battery. You need to ensure the battery ah is up to the job of sustaining the system for the specified time in the manual/manufacturers instructions. You should be able to find them online. The battery calculation is available on line. Batteries should be replaced every five years in any event. To test them you need a clever/expensive bit of kit to show they have the required charge. I have seen where these guys made their own tester with a ballast from a fluor, then test the dc voltage as it discharges. You should see the ah and date on the battery when you open up.
O enter(arrow) 7890 , will put the alarm into engineers mode on the later scantronics , then 99 enter to leave .
Scantronic panels have used 7890 as the default engineer code for the 40 years or more I've worked on them
Some panels have different levels of reset so it is possible to just reset the codes without returning the panel to factory defaults and having to completely reprogramming it
Most panels these days have a remote keypad and also a control panel quite often located in a cupboard or garage usually near the consumer unit
Ah found it I was presuming it was the keypad battery at first I have removed cover abs switched of at the mains
I persume it’s as easy as just sliding it out ?
open panel. enter user code to silence alarm. remove battery ( spade terminals). fit new battery observing correct polarity, close lid. reset panel.
Reply to Scantronic Battery Fault in the Electrical Forum area at ElectriciansForums.net
