Discuss Scantronic I-ON16 Wireless Alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
T
TPES
Has anyone installed this or know much about the system?
Click here I-ON to check the system out.
I have read a number of reviews on the internet that rate this system very highly, and is the latest it top spec wireless proffesional alarms.
Checking at my local wholsalers this system is very expensive and then when adding your labour to install seems to be a very high price for the customer to be paying.
Has anyone installed this before and what is being charged to the customer??
Im very interested in starting offering this system as one of my options but not sure if the end user will pay the total price for the kit to be installed.
Prob best for now to carry on installing hard wired systems at the affordable price.
What do you think?
As wireless systems are still a fairly new product the price will be more expensive than a wired one.
Plus the fact, its wireless, so there is no redecorating to do, quicker to install etc, so where labour cost is saved, its put back onto the alarm system.
Make sense?:D
Heard different reviews about wireless alarms, some say they are really good while others don't trust them because they say that there is too much interference with the frequency of other wireless devices. Don't know how true this is?
I would suppose it would depend on the quality of the unit as all the manufacturers state that their units are at a completely different frequency to anything else?
A common supplier for wireless alarms are ESP and on a positive note if you did install one of these types of wireless kit (apart from the easier install) is that you can usually add bits on at a later date, for example extra senors, control pads etc.
ESP Elite Security Products - Electronics Line UK Ltd. UK based manufacturer of electronic security and CCTV products.
I was looking at one of ESP's alarms once for a customer that had lots of cats because ESP alarms provide some pet sensors as an option so the alarm doesn't keep going off. :)
I have a wireless alarm system I bought when I was in France. The motion sensor does not detect pets and works fine. I bought it from alarmania . It is this model:
Also, I need to buy open door detector. I am searching a shop which sells accessories for wireless alarm system.
a cost effective systerm is the risco 595. complete kit is £220 + vat inc. 6 wireless detectors. ext. sounder and keypad are hared wired. i've fitted several and had no problems.
[MENTION][/MENTION]
The scantronic I-on is a good kit, but you do pay for it plus it comes with a wired keypad not wireless, I've been using Visonic's kit its really easy to fit all the detectors are pre-programmed it took me a about 2 hours to do my first one, I've fitted a few now had no real problems Visonic Powermax Complete Wireless Intruder Kit c/w Speech Dialler
All> I have recently installed a wireless ion-16 alarm system. I have brought and tried to set up a two way fob. Here's the problem:
1. I want to leave the house, drive the car out of the garage (wireless PIR protected), close the door and set the alarm with the fob to 'full set' - I am able to do this successfully!
2. I want to unset the alarm with the fob, open the garage door and park the car, close the garage door and enter the house. When I enter the garage the alarm goes off!!!
3. I tried parking outside the garage door, unset the alarm with the fob and open my front door - the alarm triggers and I can unset the alarm from the fob.
4. Why can't I unset the alarm, from the fob without entering the garage or the house - just as I can set the alarm, having left the house and driven the car out having locked the garage door?
Please can anyone inform me of a solution to this problem - thank you!!
Preferences
Backspace
Tab
q
w
e
r
t
y
u
i
o
p
Return
capslock
a
s
d
f
g
h
j
k
l
shift
z
x
c
v
b
n
m
shift
English
Deutsch
Español
Français
Italiano
Português
Русский
alt
alt
Preferences
Reply to Scantronic I-ON16 Wireless Alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
If you search the internet for PCB manufacturing, you will find many companies, houses, and fabs that offer cheap PCB manufacturing and...
Had a shock on our latest electricity bill. £153 for 1 month. Usually we pay around £100 for both gas and electric. Iv checked the usage and its...
I need a fire alarm installing in a house that was converted into flats 30 years ago. It comprises 3 units. Ground floor and basement maisonette...
Background: I have a ex council 1st floor flat that I bought, I moved in to care for my disabled mum and so rented the flat as I could not do...
5K
J
As an electrician, personally I've never had to install an intruder alarm. I've recently purchased my first home and am in the process of...
