CK Tools :) The professionals choice when it comes to Electrical Tools
Discuss Scantronic9448+ home alarm engineer codes in the Electrical Engineering Chat area at ElectriciansForums.net
B
Billybalata
Hi.........i(foolishly)turned my 9448+ alarm off at the mains about 2 years ago because the cat kept tripping it when it was set.
Now the cat sadly is no more(R.I.P),but on resetting the circuit breaker all is dead........a quick look in the circuit box and i find a large battery cell which i suspect is dead.
Curiously enough the circuit box is marked 9448+.........whilst the separate control panel is marked 9427..........i estimate the alarm to be 7 years old(when the house was built)
I have no manual for this alarm and no test equipment..........i was an avionics techie in the RAF 20 years ago,and whilst competent not to blow myself up i am hardly current.
My questions are
1:is it likely to be a dead battery?
2:if so will i need engineers codes when i replace the battery?
3;if so does anybody no the codes and sequences?
Many thanks in advance Bill
Instyle LED Lighting Specialists UK
ipf
Mentor
Is there a supply? If not check fuses, mains and internal. Engineers code (default) 7890, if I remember correctly. It may not have been altered. Try it (and replace the battery).
A
alarm man
  • #4
open lid,power system up,enter your user code to silence,replace battery(2.1ah long thin one) close lid,and reset,should be it,unless its crashed and will need reproging,tho should be ok,scanny are decent panels
ipf
Mentor
Agree AM. Good panels. Found problems with a 500r with interference from wireless computers though. Changed the frequency on later models, I found. Costs a fortune for replacement detectors.
K
Knobhead
  • #6
Next doors alarm is a XXXX could you give me the engineering code please.
Regards
Burglar Bill
O
oldtimer
  • #7
This panel has a NVM memory so it may still have your old user code as for the engineers forget that just now open the panel and check the battery size then go get a new one and if you buy it from screwflux or an electrical wholesaler then take the old one with you and they will dispose of it properly do not throw it in the bin. Once you have replaced the battery you will get a tamper alarm because you have the lid off put in your code to silence it and if it does not work then use 1234. connect battery and put the lid on then enter code to reset the tamper fault. Now check it out for operation ie one thing at a time
A
alarm man
  • #8
Regards
Burglar Bill
to be fair tony,the engineer code will not unset an alarm system,it only gives access to programming it,if the system isnt maintained by an alarm company they dont have the right to lock the customer out of programming his own system if thats what he wants to do.
O
oldtimer
  • #9
Agreed hence why I said forget the engineers code he needs to see if it is working but to be honest he would be better getting someone in as he needs to take it in steps and as I have found out it can end in tears
A
alarm man
  • #10
some customers will never pay mate..
ipf
Mentor
The OP said the panel is 'dead'. Before anything, is the mains led 'lit'?
Not been back, so may have solved the prob.
R
rad1o
  • #12
I know this is old now, but engineer's codes were changed in 2005. It used to be 7890
Reply to Scantronic9448+ home alarm engineer codes in the Electrical Engineering Chat area at ElectriciansForums.net
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Top Bottom
