sparkybrum
Just a quick question, in the general section of this form,
1. presence of under voltage protective devices, there are passive rcds on the cu and no dol starter, I've put n/a for this
2. Connection of single pole devices for protection or switching in line conductors only, all sockets used where DP so I've put n/a for this
3. Particular protective measures for special locations and installations, there is sup bonding to bath so I was ticking this.
Finally routing of cables In Prescribed zones, does this relate to 150mm from ceiling, 150mm from sides etc? And if I'd laid them not in those zones I put n/a?
Cheers guys
Cheers guys
