Discuss Schneider 63a single phase switch fuse in the UK Electrical Forum area at ElectriciansForums.net
got a part number?Has anyone used a Scheider 63a single phase switch fuse before?
Im just wondering whether they need crimped connections or whether its a terminal?
got a part number?
I think its SD632SFK
why scheider .cant you use some body elses .Has anyone used a Scheider 63a single phase switch fuse before?
what happening Tuesday .Because thats the only one i can get hold of for Tuesday!
He probably wants a quality one, why would he use another make.why scheider .cant you use some body elses .
From the website, picture is crap but at the bottom of the page it says 63 amp = 25mm
125 / 160 are 8mm stud
https://www.schneider-electric.com/resources/sites/SCHNEIDER_ELECTRIC/content/live/FAQS/170000/FA170463/en_US/Twinbreak tech and dimensions.pdf?_ga=2.130761095.900725407.1542640115-1093622442.1542282979
you might be having you nails done or hair,lol.What’s with all the questions
[automerge]1567190403[/automerge]
60KXSC2F - EATON EXEL 2 SP+N 63A SWITCH FUSE-DISCONNECTOR - Your Electrics | Electrical Supplies
60KXSC2F – EATON EXEL 2 SP+N 63A SWITCH FUSE-DISCONNECTOR The Eaton MEM 60KXSC2F Single Phase SPN 63A 230V Switch Disconnector with surface-mounting enclosure fabricated from rust-protected sheet steel with a light grey paint finish. Supplied with removable top and bottom endplates incorporating...www.yourelectrics.com
Reply to Schneider 63a single phase switch fuse in the UK Electrical Forum area at ElectriciansForums.net
