Discuss Schneider Domestic Consumer Units in the UK Electrical Forum area at ElectriciansForums.net
SKY
Hi Chaps
Have you guys fitted any of the Schneider consumer units from toolstation?
They seem good value.
Is there room for a RCBO setup in them.
schneider tend to be the market leaders for quality and are the head company for common brands like Square D, Merlin and Telemecanique amongst other but initially to buy the Schneider or merlin brand you pay above the odds but get good product, alot cheaper out there but not used their domestic range.... rcbo's if i remember cost approx £50 which is twice the price i can get other brands but they both do the same job and comply.
I fitted one whilst still branded Square D and TBH they look the same today.
They had plastic DIN rail and no space. They are about half the depth of Wylex
I fitted one not so long back. The moulded din rail was a lot more solid than some metal din rails on plastic struts I have encountered. Plenty room above the rail for rcbo use. Rcbos and mcbs are nice and cheap, £23 and £2.80 from toolstation. Bad points were severely limited bottom entries, lid was a bit flimsy, and a less than comprehensive label set. I would trust the switchgear all day long if its anything like Merlin though.
Not the best IMO, Bit flimsy and lack of space, On the positive side Scneider run the most comprehensive electrical company I have ever seen though, and I have seen them with mobile workshops setting up and assembling switchgear on the bigger jobs, however on the flipside they also own GET, which has a less then enviable reputation!
Reply to Schneider Domestic Consumer Units in the UK Electrical Forum area at ElectriciansForums.net
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
