Discuss Schuko adapter, but which one? in the UK Electrical Forum area at ElectriciansForums.net
Yaqub
Hi
Quick question,
I have the following appliance lying around and wanted to make use of it, it comes with a German plug with the following specs;
http://<blockquote class="Upload the image directly to the thread-embed-pub" lang="en" data-id="a/QeKflGw"><a href="//Upload the image directly to the thread.com/QeKflGw"></a></blockquote><script async src="//s.Upload the image directly to the thread.com/min/embed.js" charset="utf-8"></script> https://i.Upload the image directly to the thread.com/a8vrhke.png
1000 Watt
220/230v
50/60hz
What earthed/grounded schuko adapter will I need, a 5 amp or 13 amp? I know the UK version of the same model uses 13amp but wanted to make sure.
Thank you.
I would say that's a blue, albeit with a green hint.
When you fit the plug make sure the earth wire is a little bit longer than it needs to be. Also make sure the cord grip is on the outer sheath. I'm sure you probably know this already but best to be on the safe side.
Use a continuity tester or multimeter to confirm continuity between the Green/Yellow wire and the chassis of the appliance.
Failing that, open up the appliance to visually confirm where the wires are connected.
https://i.Upload the image directly to the thread.com/s1K4kXM.jpg
Green/yellow connected to metal
Brown links with the red cable
Green links with the blue cable
Reply to Schuko adapter, but which one? in the UK Electrical Forum area at ElectriciansForums.net
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
I have this motor from my egg rocker which the incubator was old and needed remaking, it’s a synchrononus 4watt motor that turns my plan is to...
In an attempt to isolate for certain whether my fridge freezer is causing my main RCD to trip or something else, I used an RCD adapter in the...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
