Discuss Scrap cable stripper...... in the UK Electrical Forum area at ElectriciansForums.net
Heres my homemade one, can do upto 120mm singles or armour cores (not tried anything bigger)
Also does T&E on the other side but never really use it as it's hardly worth it.
That's a beast rocboni!
Do you steal...ahem, acquire, lots of cable? LOL!
I have a modest few drums of old colour cable and had a look on fleabay where the going rate is a couple of quid and more for the old 2.5 t&e...hardly seems worth stripping it if I can sell a drum for ££££s
I do seem to acquire a lot of cable, usually because it is overordered, (not buy me) Or strip out quite a bit, got a load of 120mm armoured to strip ATM, an this only cost me about £20 for the motor off eBay. I had everything else or made it, I've got an inverter on it to control the speed. Had thousands through it to date.
anyone recommend a scrap cable stripper?
It's called an apprentice in a room with all the scrap cable piled up and a heater left on to soften the insulation. He gets a cut same as everybody else. I've seen them stripping cable and left out it's a terrible thing to do.
* Kevlar woven glove on non knife holding hand cut away from the body.
Cheers
you can use that cable if you sleeve the ends in foreign colours. save the shed some money as well.
Reply to Scrap cable stripper...... in the UK Electrical Forum area at ElectriciansForums.net
I was working with some odd singles today from Batt Cables, they seemed to have a plastic like braid between the insulation and the copper, almost...
Hi guys Can anyone recommened a decent cable stripper for flat and 3 core cables? Here's a couple ove seen online...
Has anyone come across automatic strippers to pull of the sheath of a cable already in a back box. The regular ones can do it to a degree but due...
I experienced an electrical shock while replacing an A/C Fan Coil's 120vac, single phase motor that was above the ceiling grid in an office, while...
4K
Hi all, H.N.Y. The passive, affixed to a recently bought LED security light is rubbish, sometimes it works, mostly it doesn't, no matter how...
