sparks01
Hi All, my friend asked me for some advice but im not 110% sure. He has installed a outside security light with built in PIR detection, but also wanted it to operate as a normal light when switched. So he has wired to switchlines from a 1g 2way switch, 1 switchline feeds directly to the live of the lamp the other feeds via the PIR. At the moment when you switch it either way the lamp illuminates and stays on (even if through the PIR). I want to know if when the supply feeding the PIR is disconnected (switched) and then reconnected, would the PIR reset itself and thus not operate as set?
