Discuss security lighting in the Australia area at ElectriciansForums.net
dannyv
Got a job coming up where the cutomer needs a security light on the side of the house to detect any one coming up their drive at night (long drive) how would you recommend wiring this would you come off a socket to a fused spur down rate then perm feed to the light or off light circuit to a switch obviously whatevers easier for access or overide facility (not sure how to wire an overide facility can anyone help me?
I'd prefer to come off the lighting circuit.
If you can lift floorboards, then you can drill straight through the outside wall.
Often the all in one fittings have circuitry that will allow you to overide the PIR by switching off an on quickly.
Reply to security lighting in the Australia area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
