Hi all,
My garage is fed from a fuse on the CU in the house and then has another in the garage.
It has 2 RCD's? one for lights and one for sockets.
I have the security lights and they have the Brown +'ve, Blue neutral and Green/Yellow Earth.
So the question is whats the best and allowable way to connect two of these into the existing wiring. I am assuming its not allowed to just cut the lighting supply wire and choc block the security lights into the supply.
Whats the allowable method to connect in?
I will then do the same for the security lights into the plug socket line.
Cheers for your advice.
