Discuss separating socket rings in CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I prefer the up and down method but that's probably more out of force of habit than anything. Nowt wrong with a diagram near on on the CU, RCF1 RFC2
or even better, radials !
i prefer them actually, no worries about spurs off of spurs !
then you could segregate circuits, IE living room and dining sockets, master bed and office sockets etc.....
I seem to be using radials on more jobs now, saves time on testing too :)
with a 50 way CU, all RCBOs. 2nd mortgage.
5 grand to build an extension on the house to house the new CU.
It's one of those things where I don't really have a preference as there's no perfect way whatever you do. The house I was in today started out as a single ring for the whole house. Then an extension was built for kitchen and lounge which had it's own ring. Then the kitchen was changed and needed to be RCD protected so the board was changed. So now there is a ring for the kitchen, a ring for the rear of the living room, another ring for the rest of the house and the hall sockets are on a separate radial. So unless you make sure whatever you're working on is isolated and use labelling, instict, common sense or 'the force' as a guide only you're asking for trouble IMHO.
BTW, the lighting circuits are even more complicated and it's only a three bed semi.
I bet labelling that CU was fun :)
In the end I numbered the MCBs (same as the positions in board), numbered the cables with collars, then stuck the circuit description onto the inside of the cover (Hager flip down). It was the only way I could make enough room for the descriptions and make some effort at avoiding mix-ups/confusion further down the line.
Reply to separating socket rings in CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
