Discuss Separating switch lives at fan isolator?! in the UK Electrical Forum area at ElectriciansForums.net
R
RedMarkCity
Hi guys, new to the forum, electrician two years out of my time and still learning!
Im on a site 2nd fixing at the moment, unfortunately it's builders who have 1st fixed, the problem is;
3 bathrooms, 3 PIR, 3 lights, 1 fan, same circuit, I told them that where they've taken a s/w live from
each bathroom, that at the fan isolator that the joined s/w lives will mean that any PIR activated will light up all bathrooms! Lo and behold it has.
I am trying to think of a solution, would a contactor on each s/w love solve my problems?
I've not had much experience with contractors or relay's and I was wondering if anyone could help me out?
Cheers
Use 2 channel pir's
Cheers
Tell the builders to sort their wiring out? Who exactly will be signing off this job - I know I wouldn't be issuing a cert for a job I hadn't wired.
Reply to Separating switch lives at fan isolator?! in the UK Electrical Forum area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
hello all, pardon my ignorance in not employing an electrician, however, im a diy'er whos changing the light switches in my house and came across...
Hello I have an old timed extractor fan in the bathroom which has stopped working. It has 3 wires which are black, brown and grey. I believe that...
Hi to all, If extractor fan in bathroom is autonomous does it still require isolator switch or usual fused switch will do? It runs of 12v...
Part 1. I Have 2 red wires and one brown going into my ceiling pull chord UK light switch in bathroom. BROWN AND RED into L1 and RED into COM...
