Discuss Service fuse and isolator installation in the UK Electrical Forum area at ElectriciansForums.net
M
MrJames
Hello everyone I'm new here and looking for a little advice...
What I'm looking at doing is replacing both our CU's at some point but for now I just need to replace the small secondary one
I called the DNO earlier and they've told me the only way they'll come out and remove the service fuse is in an emergency otherwise it's just an
electrician to remove it and they'll re-seal it on next meter reading.
So going on that I'll yank it myself.... CU's will be off insulated gloves and goggles will be worn and next door neighbour will do it for me if I wimp out lol!
There isn't anything nasty to watch for on these fuse carriers is there?
Here is the current setup....
Ideally I'd like to isolate both CU's separately as the secondary one feeds an outside workshop and will have a few sockets under the stairs for servers.
My plan is to isolate after the henley block, problem I'm is finding it hard to find a single pole isolator so unless someone has some suggestions should I just use a 2 pole one for each CU?
Many thanks in advance for advice or help :cyclist:
Well I don't know who your DNO is but it is illegal to cut the seals on any DNO equipment without prior authorization or in a emergency (DB on fire, unable to isolate elctric elsewhere safely etc).
"There isn't anything nasty to watch for on these fuse carriers is there?"
Possibly asbestos, you should not use a single pole isolator. This is really not a job for the uninitiated mate, think very carefully whether you want to go ahead with it. Do you have access to and know how to use calibrated test equipment?
DNO is Southern Electric I called them earlier to ask them about coming and fitting an isolator and they told me directly what I've said in my first post they only come and remove the service fuse in an emergency :lipsrsealed2:
What would they have used asbestos in for the the fuse carrier?
And yes I realise I shouldn't use a single pole was trying to avoid touching anything before the meter but just clicked the secondary CU neutral is fed directly from the service head so would get away with isolating the neutral....
I wouldn't be touching the main CU will get someone in to change that for a newer one just the secondary one I'll be attacking but thought I'd get the isolators in now to make it easier later on if it's anything to go by my neighbour offered to change the secondary CU while live lol.
Hello MrJames and welcome. It's very dangerous pulling the fuse even as a fully qualified electrical engineer. That's why most visiting DNO engineers will wear some form of arc flash protection gear. I'm very interested to know, what is the DNO telephone number that you dialled in which you were given the advice that an electrician could pull the fuse? Your OP suggests a change of policy so we'd all be very interested to hear.
- - - Updated - - -
Posting overlap. But what was the telephone number?
I believe you have to contact your supplier (British gas, npower etc) to fit the isolator, I recently enquired about this for a customer and that is what I found.
Southern Electric must have softened their stance somewhat, usually they go by the usual DNO mantra "Do Not Touch Our Equipment.
"They" wouldn't have used asbestos in the fuse carrier it may have been manufactured with it installed.
I'm confused, Why mention a single pole isolator knowing you need a double pole?
Changing either CU is notifiable Mr James.
Never ever work live when there is no reason to.
I suspect that someone at the DNO has, out of ignorance/stupidity given you incorrect information. They normally take a dim view of anyone, even a qualified electrician playing with their toys so they're likely to take an even dimmer view of an enthusiastic amateur.
As I said before, this is not a job for the uninitiated.
Ahhhh for some reason what I wanted to write contains forbidden words and I'm limited on URL's it may contain..... not helpful when I can't see it containing either!
Southern Electric is part of the SSE group and they have a specific procedure for properties within the Southern Electric distribution area to allow qualified and approved electricians to advise them in advance that they are going to remove the service cut out fuse and reseal with labels supplied by them.
It is not that they will allow any electrician to remove the cut out fuse only that specific electricians may be authorised to do this in accordance with their procedure.
If you were to remove the cut out fuse this would be considered illegal by Southern Energy.
It can also be highly dangerous, I cannot recommend that you try this approach.
Hmmm still not letting me post the numbers guess I need to hit 6 posts first? Maybe the easier option to all this for now is to use the old cooker feed that was for the old electric cooker..... I just want some plug sockets under the stairs surely it can't be this hard?
Smells like a wind up now.
Ok Mr James, "It can't be this hard"
Why do you think it takes a long apprtenticeship to become a qualified electrician?
What do you know of safe isolation procedures?
What do you know of maximum demand and diversity?
What do you know of cable selection methods and derating factors?
Initial verification inspection and testing?
Certification and notification?
That's just a few to be going on with.
When I said it can't be this hard I was referring to getting someone to agree it's their responsibility to remove the service fuse which seems to be rather difficult.... and timing consuming at the moment.
All I'm really after at the moment is 2 dual sockets under the stairs as the old cooker circuit was a large 30amp one and now only has the cooker's pilot and 2 sockets on it there shouldn't really be an issue using it should there?
Reply to Service fuse and isolator installation in the UK Electrical Forum area at ElectriciansForums.net
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
