Discuss Setting up SolarEdge monitoring Netgear WNCE2001/Homeplugs in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Search for homeplug powerline adapters on Google. It's by far the easiest way to transfer an ethernet connection anywhere in a house. You will need a pair of them if the home owner doesn't have them already. What they cost in value should more than be saved in time trying to route a cat5 cable neatly unless the router is right next to the inverter.
Like These? http://www.amazon.co.uk/dp/B004INVK...de=asn&creative=22206&creativeASIN=B004INVKP4
That could be a bit of a dreamer for me as the inverter is right next to the D.B so I can just wire a socket from the D.B, plug this in one end, and plug the other in next to the router. patch cables to connect the data side and I'm in bussiness?
Just need some luck with the monitoring side of things now!
Cheers!
the download seems to be offline- Maybe they're updating it. Have to say though, just installed our first Solar Edge and wow- it's brilliant!! Done 26kW today
Like These? TP-Link TL-PA211KIT 200Mbps Mini Powerline Ethernet Adapter - Twin Pack: Amazon.co.uk: Computers & Accessories
Cheers!
They will work, really is a great system, Monitoring is pretty easy, I used the Iphone app for the design and uploaded the .xml file they emailed me over to me. Not the prettiest of designs on the portal, maybe I done it wrong:p
Cheers!
Yep they will do perfectly Gregg. Yes I asked for the inverter to be installed on mine next to the CU and it made doing this a piece of cake once I had some extra plugs installed by my friendly electrician.
Reply to Setting up SolarEdge monitoring Netgear WNCE2001/Homeplugs in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Good evening all - I used to be a member of this forum ages ago, but couldn't work out what my username and old email address was, so decided it...
4K
Hello all Can I ask some advice please. Since the solar edge was installed, my system has absolutely outperformed itself, and done far more in...
15K
I have a SolarEdge install on a rental property. Currently my tenants are happy to give me a generation meter reading every quarter and have also...
P
Solar-log 200 Wi-Fi £500 +vat Brilliant apps on Android for £6! Cut down versions available for free. It only gives you import/consumption...
V
Hello everyone, this is my first post. I'm not an electrician, but I'm really in need of one, it seems! I have had a 4KW solar array installed...
5K
MicraShed
M
