F
fhumbert
Hi all,
I have had to replace a 2-gang dimmer switch in a bedroom.
Unfortunately, the ones I have tried were all a little too deep. By the time I had pushed them into the back box, it was quite tight against the wires. I was able to screw it on but I am a little concerned that there won't be enough space in there for any heat to go out.
I was wondering if any of you know of a range of dimmers that is particularly shallow. It could be because the modules don't protrude too much or because the face plate is itself a little deeper.
It needs to be a 2-gang dimmer in brushed steel.
Cheers
Fred
Cheers
Fred
