Discuss Shallow depth ground lights in the UK Electrical Forum area at ElectriciansForums.net
R
Rauer
Hopefully someone can suggest some that they've used,
i am putting some decking down near my shed and I want to put some lights in the decking but I don't want the little piddley type ones , I want the bigger ones( like gu10 sized ones) but here's the problem I only have about 75mm to play with on the depth , ( concrete base is below) I don't mind chasing it out a little but would rather not, I am kind of gathering that I am looking at led due to the depth
Reply to Shallow depth ground lights in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hi there - good site. Mrs wants a new socket directly below a light switch on the ground floor (says it will look neater vertically inline)...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
