Discuss Shaver socket above bath in hotel - dangerous? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
smashed
Hi, Sorry to bother you all. Last year I visited a 4 star hotel (part of a chain) and found a shaver socket in Zone 1. It was to the left of the sink but directly above the bath. I could definitely see a risk for a small child standing in the bath.
I emailed the hotel to warn them and they said they would investigate and check all rooms.
I returned to the hotel nearly 12 months later and found the same positioning in a different room.
Is this legal or am I being a PITA over nothing?
Well..... its a SELV unit so not out of the question in that location, but I certainly wouldn't place one there by choice!
Tin hat on!
Being a isolated unit, the earth potential is removed via the transformer, so the risk potential is removed, we now have L1 & L2 with no neutral........But I would say, although isolated, why increase the risk by installing it in such a position.
Thing is......brings us back to the debate about socket outlets in bathrooms, and the fact that the UK is the only place that has kittens over it - it's COMMON in many many other [developed] countries.
Very common in most European countries, not just upcoming.....examples are Spain, France, Italy, Malta etc. With many using IP rated washing machines...they still install away from the bath itself.
I think the biggest issue here is the potential for that socket to be splashed/sprayed by the shower (if there is one attached to the bath) filling it with water and corroding its internals.
Thanks all... I had read from the 17th Edition wiring regulations that..
  • [h=4]Locations containing a bath or shower[/h]This section has been modified according to European documents, and requires that:
    • Separated Extra–Low Voltage (SELV) socket outlets and shaver socket outlets are permitted outside Zone 1. 230 V socket outlets are permitted provided they are more than 3 metres from Zone 1.
I was worried that they have done nothing about this despite me warning them that it appears to contravene the regulations. Mind you, I assume no other guests have noticed / worried.
Thanks all
There is no shower attachment (you can probably see this in the reflection in post #1) . I assumed it would be a signficant shock to a small child if he stood in the bath and put his wet hand on the wall.
But in a hotel where you don't clean up there could be and would be water everywhere large splashes of it rather than a shower spray
Which one are you dingle?
Reply to Shaver socket above bath in hotel - dangerous? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I commissioned an EICR to be done on a property that is in Wales as this is now a requirement in order to let on any new tenancies after 1st...
So this was an interesting conversation today and wanted peoples advice. Plumber asked me if I could fit a socket inside an enSuite Vainty unit...
4K
Hello everyone, I hope nobody minds that my first post is a question. We have a bit of a situation brewing at home with regards to our new...
4K
My first posting and hope you guys can help. I am a householder in the process of planning a refurb of our bathroom (not DIY) and putting together...
Hello i've recently just had a re wire done on a three bed semi house, Ive noticed a few things im not 100 percent on ive spoken to the firm that...
5K
