Discuss Shielded cable question. in the The Welcome Forum area at ElectriciansForums.net
Hello, and thank you for reading this!
I have a question regarding a shielded cable grounding.
I need to wire double shielded cable and eventhough the manual instructions are quite straigh forward I'm not sure what to do. Theres 8 wires inside it and one of them is optic fiber. The fiber wire is assigned to functional earth/shield. To ground the device I'd just connect the shield to the grounging in the control box. What should be grounded: shield, optic fibre or maybe both?
Or am I getting it completly wrong?
The cable will be connected to SICK S300 mini safety scanner, if that changes anything.
I hope someone can help to educate me a little :)
Thank you in advance!
Izabella
Can you share a link to some form of technical spec for the cable you are using?
You're getting something confused as fibre isn't influenced by electrical noise and wouldn't normally have a shield
Reply to Shielded cable question. in the The Welcome Forum area at ElectriciansForums.net
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
I was wondering if someone could assist me in determining whether I can replace my current 3-way switch configuration with an Enbrighten smart...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
Hi, folks.' I have a carrier 38MGRQ48E '5 zone' mini split system with 4 'heads'/evaporators installed, and one 'channel' still open. Had it...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
