Delta power is still common for general LV applications, with a line-line voltage suitable for single-phase loads e.g. 230V in Europe. Ships built in the EU for operation in territories with US-derived wiring conventions may have multiple systems operating at different voltages.
An example of where delta can be a nuisance is entertainment installations on cruise ships. A well equipped vessel might have two dozen full height racks of audio / video / lighting control equipment, of variously EU and US spec, single and 3-phase input, sometimes 3-phase input but single-phase output, which is where chaos sets in if it is not internally reconfigurable for delta or double-pole fused. One of my colleagues has just managed to get a spec approved for all entertainment systems on a design he did last year to run from a 400/230V star supply, which simplified things his end. IIRC he had to have four additional substations put in, totalling 1.2MW on some 400 circuits.
I remember doing some specs for a similar ship 25 years ago, where we had four independent supply systems at different different voltages to deal with loads that could not be reconfigured or were not available in different voltage variants, or we wanted to use a higher voltage because of cable run lengths etc. IIRC the 120-0-120 single was separate to the 240 delta, but was also had a 208 delta. It was pre-harmonisation and we had to meet UK, Italian, Norwegian, US and Lloyds requirements at the same time. There were some issues with what the function of a black wire should be.
