Discuss Shock horror i extended a 4mm radial with 4mm today! in the UK Electrical Forum area at ElectriciansForums.net
Top Cat
Had to spur off a 4mm radial today at a twin socket to feed another socket so there were 3 x 4mm in the socket outlet.
Now i know that this is a hideous crime for a lot of sparks so i took special note of what i was doing.
1, there was enough room in the socket.
2, the terminal screws were not proud of socket
3, you can't actually make the screws proud by undoing them to there max
4, i measured the depth of the screw head once screwed up and it was down 5mm
5, i can do ring circuit testing before you bring that old chestnut up
6, Still probably be vilified by some
7, Don't care! :smoking:
so what's wrong witr it, apart from your terminology. you don't spur off a radial, you branch off. as for item 4. in your post, that's easy measured with your claws, anything over 5mm, get the buggers clipped..LOL.
Nothing wrong witr it at all Tel!
Try telling that to E54! :rolleyes2:
E54 is a bigger pussycat than you are as long as you give him 20ft long rods.LOL.
three 4mm's in a 13amp socket?
lol!!!!!!!!!!!!!!!!
Never!
Its Impossible!
Dangerous!
Children will die!
You'll end up in jail!
lol!!!!!!!!!!!!!!!!!
You obviously dont know how to do RFC testing you silly useless Electrical Trainee boy!
lol!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sorry....just thought I'd save him the trouble.
HA HA HA HA I KNEW WHERE THIS WAS GOING gold medal goes to TC
Reply to Shock horror i extended a 4mm radial with 4mm today! in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
5K
I have a dedicated radial from the consumer unit to my conservatory. This was installed using 4mm twin and earth as it gives the option to use...
7K
The seller is saying they will not upgrade the electric and it is normal to have 100 amps. However the inspector is stating it may trip often and...
Morning all, I‘d really appreciate some advice - not a kick in the pants please - from those more knowledgeable than me! My new kitchen and...
6K
