Discuss Should I use a contactor or a relay? in the UK Electrical Forum area at ElectriciansForums.net
J
Jay
I have to design a unit which utilizes both 24V and 110V for lighting. We will supply these voltages by using a dual type transformer. The 24V will supply an alarm and heat tracing whereas the 110V will supply a lighting circuit. Should I install a contactor or a relay to protect from under voltage for the lighting?
Why is it necessary to 'protect' the lighting circuit from under voltage? To offer any help to the parts you cannot workout for yourself we would need your full design brief!
......Andy;~)
depending on your current load you could use both
for example you can use a relay for small lighting requirements such as a couple of lights.
but if you want to control bay lighting in a warehouse or a lot of lights you should use a contactors controlled by a relay
(3 pole contactors) you can control multiple supplies this way
Reply to Should I use a contactor or a relay? in the UK Electrical Forum area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
