Discuss shower and power circuits in loft in the UK Electrical Forum area at ElectriciansForums.net
hi guys
anyone have any good ideas re routing shower circuits in the loft space when the amount of insulation means the joists are not even visable ?. i was thinking 25mm conduit supported via rafters, or building a batten run above the insulation and clipping to that. any ideas for where the cable passes thru the insulation for the switch and the shower unit ?? all i can think of is a piece of drain pipe to keep the insulation away. any ideas would be appreciated.
Batons to clip to and guttering downpipe to pass through the itchy stuff. A couple of batons between joists and pipe brackets will hold it all in place.
Reply to shower and power circuits in loft in the UK Electrical Forum area at ElectriciansForums.net
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Evening all. Been at a property the last couple of days that had suffered damage due to a surge. I got the power back on all circuits apart from...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
So that I can understand how the electrical energy that I consume is being used I want to fit one of these to my consumer unit (CU) -...
6K
