Discuss Shower isolator in the UK Electrical Forum area at ElectriciansForums.net
local isolation is good practice, but, as the shower can be isolated for maintenance at the CU, i see no reg. that stipulates it as necessary.
Double pole isolation?
Good point...
I can put a DP isolator in the loft space above, or cupboard nearby, I was just trying to avoid having a hideous big switch in the nice new bathroom!
Install the switch outside the Bathroom then, not rocket science after all.Good point...
Is double pole isolation required? I'm looking at 537.2.6:Double pole isolation?
Does turning the 100a main switch off count? Regardless I always fit a local isolator either in the form of a pulled or sometimes people prefer a switch outside the room or hiddenDouble pole isolation?
I've seen a couple of the crabtree models broken too. In both cases the switching mechanism had failed due to overheated loose connections. The casing and base were all very well preserved from the effects of heat though.Agreed, I’ve seen a fair few burn. I’ve always assumed it was due to poor termination of screws and cheap isolators. On the odd occasion we do fit them it has to be the Crabtree or Hager unit. To date not had an issue with them.
Reply to Shower isolator in the UK Electrical Forum area at ElectriciansForums.net
