Discuss Shower supply in the UK Electrical Forum area at ElectriciansForums.net
N
Norn Iron
Hi everyone need a bit of guidance, I have a shower to wire in an upstairs flat. It is an old fuse wire dist board therefore I am installing a shower consumer unit. The run of cable is only approx 4 metres as dist board is just on other side of bathroom wall. On the consumer unit I am going to install it has a 40A 30mA RCD and a 40A MCB will this RCD be suitable or will it need to be upgraded to a 63A 30mA RCD. The shower is only 8.5KW and will be wired in 10mm.
use 6mm, then if they want a bigger shower at a later date, you got yourself another job.
It's in his user name :) (Northern Ireland) pronounced locally as Norn Iron
Reply to Shower supply in the UK Electrical Forum area at ElectriciansForums.net
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
