Discuss shower? in the Australia area at ElectriciansForums.net
R
roboze
Hi all its late and i`m tired:confused:,
Just fitted a new shower in my own house, question is, i have installed a new circuit for shower.
can i get away with a minor works?
been so long since i`ve just installed one circuit anywhere i cant remember if it`a minor works, or full EIC cert.
and to tired to look it up!
Thx all :cool:
No you need an EIC.
what sintra said EIC. get your pen out.
yes and no. you have to test the installation, i.e. earthing, bonding, Ze , your new circuit. you do not have to test other circuits, so your scheduile of tests will only have the one circuit parameters.
thanks yes i remember now :p,minor works certs are for alterations. phew for a horrible moment i thought i`d have to do the whole lot.
as it's your own house, i'm surprised you don't want to do a full installation test for your own peace of mind.
Reply to shower? in the Australia area at ElectriciansForums.net
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
At a bread and butter job, loose socket, socket not working, change two lights. Sticking out rather like a sore thumb was this (I removed the wire...
