Discuss Shunted? in the DIY Electrical Advice area at ElectriciansForums.net
james2
Hi all, I'm doing a simple fluorescent to LED retrofit, looking for confirmation on whether the tombstones are shunted or not. I'm seeing instructions to use a multimeter on continuity mode to check the circuit and verify. All I have is a simple analog voltmeter (photo below), which isn't registering an open circuit when I test it, but I'm wondering if that's sufficient to tell me if it's shunted or not, or if I need to get a more sophisticated multimeter for that? Also including photos of the tombstones in case it's immediately obvious to anyone from the visual. Thank you!
View attachment 62680View attachment 62683
The meter you have appears to only measure voltage and and not have an ohms setting to read continuity. You can purchase cheap meters at Home Depot and Lowe’s
Reply to Shunted? in the DIY Electrical Advice area at ElectriciansForums.net
Forgive me if this is easy to search - I was not able to find anything obvious here or on YouTube. I've got an outdoor circuit that has failed...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hello! I design and build lamps, which has been a simple task so far, but I've decided to dip my toe into the dubious world of 120v LED PCBs for...
Howdy, I'm looking for help with my plan to install an extra internal double socket and an external double waterproof socket to my garage. I...
