Discuss Signing off your work in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
BeatoX
hey guys i just recently started a new job wiring up heating systems basically i strip out the old boiler and revolver supplys then the plumbers come in and fit the new boiler then i wire and fit a new thermostat and connect everything up at the existing boiler spur and fit a new CO2 alarm in the vicinity by stealing a supply from the nearest source
so basically what i want to know is what qualifications do i need to sign off my work i am 17th edition C&G working in scotland with a valid cscs card and i am thinking i need to be 2391 certified and issue a minor works certificate to sign off on my work by carrying out a IR test and a earth continuity test is this right??
you don't say if you work for yourself or for a firm. if you are self-employed then you are spot on with your npost. if you work for a firm, praps they have a 2391 qualified tester who can sign your work off.
If you go to the ESC worksite they have a download of the scottish Regs regarding what is needed. In england all CH work is notifiable and therefore you either have to contact building control or be part of a part P registered person scheme.
i'll check that out mate i know in scotland part p doesnt apply
telectrix i work for a company but as its mainly a heating systems company so i am the only spark on the job and it would also benefit me being able to do this
will your employer fund your 2391? if so, go for it
Reply to Signing off your work in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In 2019, I had a lot of renovation work done including a full re-wire of our three storey house. Before the re-wire was finished, we parted...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
Evening all, I just wanted to see if electrical improvers/adult trainees with appropriate levels of experience and who hold testing...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Just looking at my boiler wiring out of interest, and just wondering if it's wired correctly. So perma lives, neutrals and earths in the right...
5K
