Discuss Simple light circuit in the Lighting Forum area at ElectriciansForums.net
need some help with a light circuit, we have 2 of them klik ceiling rose lights on its own circuit with 1switch and an emergency key switch.
Both lights operate on and off when the switches are opened and closed however the em light battery kicks in whenever you switch the lights off so acting as if there is a power failure every time. Obviously it needs to be off but then only operate the backup battery when the emergency key switch is operated.
Novice problem probably but anyone help with this? Thanks
The permanent supply is being switched. It shouldn't be until the test switch key is operated.
It's wired incorrectly.
I suspect the lives are either connected wrong in the switches or Klix plugs/sockets. Easy fix for an electrician.
Reply to Simple light circuit in the Lighting Forum area at ElectriciansForums.net
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
