Discuss Single Gange Outlet + Dimmer Switch in the Electrical Forum area at ElectriciansForums.net
ksdennis
I am looking for a single gang outlet + dimmer switch combination.
Does such an item exist?
It's for a kitchen backsplash the outlet would be unswitched and the dimmer/switch would control a light over the sink.
The whole backsplash is on a GFI so I don't need a GFI in this device.
-Kevin
-Kevin
A single gang box won’t work, it sounds like you need a 2 gang box for the dimmer and receptacle and if it is already GFCI PROTECTED the you can add a regular receptacle but you need to install a sticker saying GFCI protected
Reply to Single Gange Outlet + Dimmer Switch in the Electrical Forum area at ElectriciansForums.net
