C
chloebear
Hi all,
I hav a requirement to convert a single phase supply into a 3 phase supply - the feed cable from the main dis board is 25mm SWA 3core and I require (strangly enough) 4core as a minimum to convert the board to 3 phase - the question is, would it be acceptable to run a new 2core cable for Neutral & Earth leaving the 3 existing cores as the 1/2/3 phase cores????????
The run is about 70 metres and to pull in a new 4 or 5 core cable will be a problem.
Any thoughts and guides on theis would be greatly appriciated.
