Discuss Singles in a partition in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
E
estebandonde
Hi Guys,
I'm a bit rusty but I've just seen single cables installed in a stud partition used for sockets etc. I've never seen this done before but can someone confirm if this is ok?
I seem to remember that they should be double insulated (T&E) or single + mechainical such as conduit/trunking etc
or does the partition act as a mechainical protection???
cheers
Been home for lunch :) and found my regs book, 521.10.1 states that "Non-sheathed cables for fixed wiring shall be enclosed in conduit, ducting or trunking. This requirement does not apply to a protective conductor complying with section 543
So no singles allowed in a stud partition unles in conduit, flexible conduit etc.
cheers all
Just an FYI, T&E are not double-insulated but insulated and sheathed. It is the sheath which forms the mechanical protection (as you pointed out), so without it the cable must be protected by conduit or trunking. :)
and if the studding is metal, RCD irrespective of depth.
Reply to Singles in a partition in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
