Discuss Size of Submains in the Australia area at ElectriciansForums.net
kevben
Got some one bedroom flats to wire & install Submains. Usually would install 25mm 3 core SWA (just to cover myself) but prices are tight.Flats only have lighting, sockets and cooker as heating supplied with Gas boiler.
Question is:- Would 16mm 3 core SWA be ok
sounds to me like it will be ok. a family home with 4-5 bedrooms and garage withoutside lights ect will usually have 100Acutout and 25mm tails, so in your situation i think 16mm will be fine. i tonged my tails a few years ago, when i lived in a 1bed flat, with cooker on full (oven too) and all lights, tv, iron ect, and it was 45A.
Have you ever used split concentric cable, no terminating into glands and use k.m.f switches instead of sp+n switched fuse(metalclad)
im sure you will save some money this way.
Reply to Size of Submains in the Australia area at ElectriciansForums.net
I’ve got a job to quote for turning 1 big flat into 2 smaller flats. The DNO are looking at installing new meters in the communal area. I need to...
Hi all, I’ve been given 3 flats to re wire and i was looking for advice on the correct size Swa to use. There will be 3 meters installed by the...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
I'm hoping somebody can help me. Im converting a 4bedroom flat to 3 x 1bedroom flats. I am having a new 3 phase supply installed for 3 the...
4K
