Discuss Sky confusion? in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
afternoon gents, long time since my last post but hopefully someone can help me out?
Got a question for you guys as I can't get hold of sky at all!
I'm a spark and I'm wiring a house for a customer and I'm running all the sky cables (shotgun Webro) but I don't know weather to run them all to the LNB and if so what direction of the house should I run them too? (I'm sure I have heard the satalite is astra as should point South East) If not, do I run them all to the loft and leave them to sky? As she hasn't got sky yet I can't get a proper answer from them? Hopefully you could help me out?
Thanks In advance
Thanks In advance
Sky is positioned 28.8 east, best way to find it have a look at their neighbors where their sky sat is and take them there.
How you wiring the free view cables? 2 ways to do it run a cable from outside into the loft and and then run them from there to each tv point or from sky box f out to loft and use amplifier to boost the signal. of course you need power for amplifier.
Cheers fellas,
yeah im going to run all coax from each point to amp in the loft which comes from the Ariel but it was the sky that was making me think to much! Customer doesn't want the cable on show if possible so want to make sure it's not on the wrong side of the house to where the dish will be mounted! Besides the size of the LNB will be bigger than the dish lol
The Astra satellite is at 28.2E, The sky is right above you
OP I would suggest using Satellite Finder / Dish Alignment Calculator with Google Maps | DishPointer.com to get the best dish location on the property you are working on, Dishpointer is also available as a phone app if this is easier for you. I use this site all the time as it also gives dish elevation, LNB skew and reports any possible obstructions in the signal path
Yes you are right it is 28.2 E and yes sky is above you too.
Reply to Sky confusion? in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi all, Looking for some advice on first fix for sky and freesat TV, I've quoted a WF100 shotgun and a single to both bedrooms and lounge...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
Hi all, just a quick query really. I'm and apprentice on me second year and currently doing my design project and confused about length of run...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
