Discuss SKY HDMI CABLE HELP in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
GarryJ
Hi there,
I have run a brand new 50ft HDMI cable which is good quality and has built in booster to run from my main sky box which is in another room from the main TV I use. The cable etc is all ok as I have tested it with DVD player and Sky Q box which I took from a neighbour however when I plug this cable into sky all I get is "This display is not compatible with HDCP" however the TV is fine with it when connected to another source.
Can anyone help me? Is there anything I can do or plug into the older style sky box to make it work with this cable?
Thanks in advance for any help
Hi there,
https://www.amazon.co.uk/dp/B004F9LVXC/?tag=hotoge-21
https://www.amazon.co.uk/Splitter-A...&qid=1484682432&sr=8-1&keywords=Ckitze+BG-520
Try taking it through a splitter that ignores high band-with digital content protection.
OP if your google 'This display is not compatible with HDCP' you see some other things to try. No wishing to tell you how to suck eggs, have you connected the cable the correct way round?
A friend of mine installed such a cable slightly longer, and has never been able to get it to work. I believe for a cable of 15m, you might need one of those splitters Lee mentioned, possibly Sky trying to stop users doing their own 'multi-room!'.
Have you tried connecting the Sky Q box with a short HDMi to the TV? Sky Q has been giving us lots of problems so I would be looking at that as a problem. Also make sure its not set to 4K as early 4k TV's aren't compatible
Reply to SKY HDMI CABLE HELP in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hi all, Looking for some advice on first fix for sky and freesat TV, I've quoted a WF100 shotgun and a single to both bedrooms and lounge...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hi all, I have a light in the under stairs cupboard which is controlled by a switch in the hall. The under stairs cupboard is being taken...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
