Discuss Sky issue after moving in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
E
eddiecme
Quick question about sky when moving house.
I don't have a sky subscription just use my box for freesat (if thats what you call it) anyway, moved to a new build block of flats plugged my two ends in to the sat point and no signal.
I took off the face plate and connected the cables straight into the back of the box, still no signal.
Traced the cables back to the booster/switch, whatever its called, in the riser cupboard and terminations seem good.
Am I being silly or i have to do something to the skybox? any ideas or anything i can test?
cheers
eddie
thats strange as vision is usually reliable stuff. Try getting an analogue signal(standard tv only) through the outlet too eliminate freesat box. Otherwise you really need a tv engineer with all the test kit as your Pi**ing in the wind otherwise. Could be damaged between the booster and outlet!
Reply to Sky issue after moving in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi everyone, I'm a newbie to the forum, and I'm hoping my question won't be too stupid. I'm in NYC (Manhattan), and have an apartment where a...
Hi all, Looking for some advice on first fix for sky and freesat TV, I've quoted a WF100 shotgun and a single to both bedrooms and lounge...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Has anyone had encounters with rogue landlords? I will tell my short story (and keep it as short as possible) I had a call a few weeks back from...
6K
Hey everyone, lately I've been trying almost everything to reduce the electrical noise over my Be Quiet Straight Power 11 850W 80+ Platinum PSU...
