Discuss Sky plus to nine positions. in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
you need a quattro LNB at the dish, 4 coax back to a central point. If you want to allow for sky plus at all points you need two satellite points at each position so you would need a satellite multiswitch with at least 18 outputs. Wire back 2 cables from each point to the multiswitch position. Also consider if there is going to be an aerial for freeview, if so allow another coax at each tv point back to a central point and install a tv splitter unit also.
If you use a multi switch you will often find they allow for dual sky feeds, terrestrial TV and fm/dab inputs on one unit, you can then run all of this down two cables too each TV point where you can have a quad plate that will give you 4 desperate outputs for satellite, TV and radio
Reply to Sky plus to nine positions. in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
Hi, I have run some outside lighting for a customer in Hi-tuff cable. He now wants 2 additional lights run across scaffolding which has been put...
Electrical2Go - Beginners Guide to Positive Input Ventilation (PIV) Units: A Solution to Indoor Air Quality Woes A guide to Positive Input...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
What's best practice if running cable from garage out to outside double sockets? I'm re rendering that wall and thought it'd be nice if I could...
