Discuss Sleeving on Stapper Cable in the DIY Electrical Advice area at ElectriciansForums.net
NeilRob
I am about to change two, two way switches which have the old colours Red, Yellow and Blue for the strapper cable, only the black switched live to the ceiling rose has a piece of red tape on it to idenitify switched live, should the Yellow and Blue also have red table on with these also being live.
they should be red sleeved/taped, a minor infringement though if not.
Yes they should have been, but red is no longer used as an identifier for 240V AC single phase line conductors. Brown is.
Ensure these switches are made dead and safe before working on them.
Reply to Sleeving on Stapper Cable in the DIY Electrical Advice area at ElectriciansForums.net
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Is blue neutral or earth when there is a black cable (which is the old neutral) - old system? Other one is red, no green / yellow
Am fitting a new pir led floodlight . The exsisting light is connected to 4 core round flexible cable, core colours green/yellow, blue, brown...
