Discuss sma optitrac update on an HF in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
poheZ
Hi
Just received the right.bin file for the optirac software for a 2500hf. Rather bizarrely the email mentions i must have at least 1kw of dc power to enable the update to go through otherwise i may damage the inverter?!
Has anyone who has done this experienced this or been told this? This is the first time i have been told this and the 1kw of power is not mentioned in their sd update manual
that's odd. I agree that you need to have enough DC power available to enable the inverter to initialise fully after the update, but 1kW sounds a bit like they're just trying to give themselves plenty of margin for error to avoid people starting the process near the end of the day without realising how long it might take.
Yes, that is what i thought. However, there is nothing mentioned about this in the manual.
Infinity
I am not sure what HFs have optitrac as a factpry set, but this particular one did not and it has a bit of shading. Of course the uk SMA helpline gave me the wrong .update file. I can email it over to you if you pm. I keep a 2gb sd card for such upgrades on me in my fluffy pencil case!
Infinity
my SMA 3000HF came with it, but wasnt preset with it to use
Reply to sma optitrac update on an HF in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We have this Swiss-made Dixi horizontal borer from 1957, very nice machine still with its original DC variable voltage drive. In those days there...
have sma 3600tl inverter, done tests on each individual panel as installed also each string when connected together got results. then see my...
R
Five days without solar but guess I haven’t missed too much yet, thanks to the grotty weather. I’ve had my solar installation since June 2011...
4K
iconnect
I
Was at the SEGEN conf earlier today. Intention is for presentations to be available to those with logins tomorrow. Picked up some snippets that...
I
Has anyone had any experience with increased voltage levels caused by PV systems affecting any of the installed equipment on site? Had to reset an...
IronLiver
I
