Discuss Sma sb4000-tl in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Stevesolargill
Installing our first 4000-TL on Monday and are just wondering if we have to do anything else other than change the 2 dials to G83/1 before we switch on??
Thanks in advance
SMA guidelines for 4000TL are DC strings and AC cable should be minimum 6mm. (although the panels will be in 4mm)
Good luck getting 6mm flex for AC isolator to inverter LOL :pimp2:
Did you pre-apply for the connection under G83 stage 2? The DNO would have written back with whatever stipulations they require to allow the connection - this may include changing a setting or two in the inverter.
I wire inverter to adjacent isolator in 4mm, then 6mm from isolator to wherever. Can't see a foot of 4mm flex knackering up the volt drop that much :devilish: Are you sure they stipulate 6mm for DC? Never run anything other than 4mm on the DC side for sub-4kW domestics.
Yeah definitlely 6mm but i have now looked on sma web site and the instructions seemed to have been updated and now i cant find it.
Honest. I aint lying i aint.
Damn you SMA.
(Err we never did it in 6mm unless it was a very long run but hey what they want isnt always what they get shhhh LOL)
Reply to Sma sb4000-tl in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, A few months ago we had a Triton Martinique 8.5kw shower installed. We've noticed that the temperature seemed quite low. Its what I'd...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hello everyone, I'm wondering if someone could help me with some EICR coding. I am aware that bringing mains tails into a fire rated consumer unit...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
