Discuss SMA Sunnyboy 4000TL and Sunnybeam / bluetooth repeater setup in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
B
bambi
Hi, my first post here. I've got a Sunnyboy 4000TL in the workshop which is at the bottom of the garden. I have a Sunnybeam in the house, and the range isn't good enough, so we bought a bluetooth repeater to extend the range. It won't work properly and says that the netID is 1 which according to the instructions, is fine when you have 1 inverter, 1 sunnybeam and 1 laptop / PC running the sunny explorer software. Any ideas?
OK thanks - I did think as much, but hoped that we wouldn't have to change the netID. I presume that the PV will have to go off to set that, as the case will need to be opened?
Reply to SMA Sunnyboy 4000TL and Sunnybeam / bluetooth repeater setup in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We are going back to a customer we installed a couple of weeks ago as we are not happy with the performance. I want to take a reading from the...
Hello everyone, I'm having a few problems with linking an SMA wireless bluetooth monitoring device to an inverter. The inverer is an SMA SB 1700...
C
I have a newly installed system with an SMA Sunny Boy 4000TL inverter plus, supplied in its box, a Sunny Beam display. I've found the setting up...
11K
ChrisHowes
C
M
hello all just finished my install sanyo and sma 3000hf and i have connected sunnyweb box. but keep getting 'registration to sunny portal failed'...
morpheus75
M
R
We have just finished installing a PV system for a system with a bluetooth enabled 2000HF inverter. Bascially as the customers is not completely...
7K
