- Reaction score
- 13
Discuss Small consumer unit in outbuilding. in the Electrical Forum area at ElectriciansForums.net
Thanks very much!Not your first time on the job I think!
looks nice, 1 to be proud of.
Big boots to fill in then.follow fathers footsteps
Picky picky picky. Not bad could do better.could have trimmed a little less insulation from the grey N wire!!
Only size 9, maybe 10 with thick socks.Big boots to fill in then.
If he got the cu wrong,might be a big shoe up is, what time is it.Only size 9, maybe 10 with thick socks.
Welcome to the forum! Your dad's installs are badger rough, so you should easily be able to improve on them
Thank youYour conductors could possibly have been a bit neater and a little more straight.
Beautiful job Junior, bet your dad's proud
They look like something out of Tate Modern compared to mine after a liquid lunch on a Friday!Your conductors could possibly have been a bit neater and a little more straight.
Thanks Tim! Ill post an RCBO board when we next install one for sure.Great job, well done! It must be a nice moment for your Dad having a son produce work like that.
I look forward to seeing an RCBO board with SPD at the origin of the installation very soon!
what like Tracey Emin fell out of bed jobby.They look like something out of Tate Modern compared to mine after a liquid lunch on a Friday
Will you shut up, I'll be pestered into forking out for one ! Anyway there's enough to put up with without a talking screwdriver !Next question. Did you use a torque screwdriver, set to 2.5Nm as stated on the front of the breakers?
Reply to Small consumer unit in outbuilding. in the Electrical Forum area at ElectriciansForums.net
