Discuss Smart lighting,plug & play ? in the UK Electrical Forum area at ElectriciansForums.net
Installing smart lighting without the plug & play flying leads,fitting Klicks ,to each fitting,then a control pair to each light.
Just wondered ,if you guys do the same,surely if it’s smart then you would use the necessary leads.
The system looks good on paper but I think our company making a pigs ear of it.
not understanding post. play this and all will become clear.
That’s a standard way of wiring DALI.
Are you using 4/5 pin Kliks?
LNE / Da Da
Easiest and neatest way would be a 5 core cable to a klik rose, then plug out to each device with 4/5 core flex
Few different ways of wiring for Dali though, depending on circuit lengths, etc..
Alot of the dali wiring systems for grid mounted fittings have a 5 core flex between them that just plug into the fittings and cable tie onto the ceiling grid.
Nothing wrong with what you are doing though, so long as the dali pair isnt just clotheslined between 2 fittings
Reply to Smart lighting,plug & play ? in the UK Electrical Forum area at ElectriciansForums.net
We have a meter EDMI - ES30B fitted to our property. I understand from the fact sheet for the smart meter...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
